Lecroy 9361 vertical resolution
I'm using a Lecroy 9361 connected by GPIB to a PCI card. Everything it's working fine. I'm using the driver pack lc936x and particularly the subVI calls LCDSO Read Wave 1 (Single). The problem I have is the vertical resolution. I really would like to increase it and so far I couldn't fine a way to do it...
Hope someone can help me!
Many Thanks,
Roberto
(3,441 Views)
Hi Roberto,
I believe the VI you are most likely needing to edit is the lx936x Vertical Setup.vi which allows you to set all these attributes
All the best,
(3,417 Views)
I'm very sorry to say there is no vertical resolution change in the lecory 9361 vertical setup.
(3,121 Views)
Hi Roberto,
Thank you for posting on National Instruments' forum.
You can set the vertical resolution : you have to change the scale (V/div) and/or vertical attenuation in the LC 9361 Vertical Setup.VI
Romain P.
National Instruments France
(3,104 Views)
