Lectura del puerto serial e impresion de datos
Wire the ascii code for a comma into the termination character input of the Serial Configure.  Decimal 44 or hex 2C.
But it would be more logical to program it to send a linefeed character which is ASCII code decimal 10 or hex 0A.  The serial configure already defaults to linefeed as the termination character.
Message 11 of 49
(2,320 Views)
Can you help me with an example? I got the idea about Arduino, but I'm new to using LabView, I owe you one for help me, thanks
Message 12 of 49
(2,320 Views)
How can I wire the Property Node to just accetp the data that come from write "L" for example?
Message 13 of 49
(2,313 Views)
Accepted by topic author cesarjr.1991
I have no idea what you mean by this question.
Attached is a much simpler VI that will work.  You just need to program your Arduino to send the LF character at the end of every message it sends out.
Message 14 of 49
(2,307 Views)
Really thanks! It works, but just for 10 seconds 😕 after that I have this problem.
Message 15 of 49
(2,289 Views)
Did you change the code in your Arduino?  That message tells me you hadn't received the termination character.
A slightly better version of the VI that takes care of some missing wires and indicators.
Message 16 of 49
(2,275 Views)
No my friend, I don't know what I have to change, and What is the mean of this " 100" in write block, this is my Arduino code, What I have to change?
#include "TinyGPS.h"
#include "DHT.h"
TinyGPS gps;
#define GPS_TX_DIGITAL_OUT_PIN 5
#define GPS_RX_DIGITAL_OUT_PIN 6
#define DHTPIN 22 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE);
char in,p,s,t,g;
int temp, hum, solenoide1=50,solenoide2=51,on,leer,cont;
long startMillis;
long secondsToFirstLocation = 0;
#define DEBUG
float latitude = 0.0;
float longitude = 0.0;
float alture=0.0;
void setup() {
#ifdef DEBUG
Serial.begin(9600);
#endif
dht.begin();
Serial3.begin(9600);
// prevent controller pins 5 and 6 from interfering with the comms from GPS
pinMode(GPS_TX_DIGITAL_OUT_PIN, INPUT);
pinMode(GPS_RX_DIGITAL_OUT_PIN, INPUT);
pinMode(hum,OUTPUT);
pinMode(temp,OUTPUT);
pinMode(solenoide1, OUTPUT);
pinMode(solenoide2, OUTPUT);
startMillis = millis();
Serial.println("Starting");
void loop() {
readLocation();
while(Serial.available() )
in =(byte)Serial.read() ;
if(in=='L')
Serial.print(latitude, 6);
Serial.println(" ");
else if(in == 'l'){
Serial.print(longitude, 6);
Serial.println("");
else if(in == 'a'){
Serial.print(alture, 6);
Serial.println("");
else if(in == 'T'){
temp = dht.readTemperature();
Serial.println(temp);
else if(in == 'H'){
hum = dht.readHumidity();
Serial.println(hum);
else if(in == 'p'){
digitalWrite(solenoide1, LOW);
digitalWrite(solenoide2, LOW);
else if(in == 's'){
digitalWrite(solenoide1, HIGH);
else if(in == 't'){
digitalWrite(solenoide2, HIGH);
void readLocation(){
bool newData = false;
unsigned long chars = 0;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 1000;)
while (Serial3.available())
int c = Serial3.read();
//Serial.print((char)c); // if you uncomment this you will see the raw data from the GPS
++chars;
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
// we have a location fix so output the lat / long and time to acquire
if(secondsToFirstLocation == 0){
secondsToFirstLocation = (millis() - startMillis) / 1000;
Serial.print("Acquired in:");
Serial.print(secondsToFirstLocation);
Serial.println("s");
unsigned long age;
gps.f_get_position(&latitude, &longitude,&age);
latitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : latitude;
longitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : longitude;
alture=gps.f_altitude();
alture == TinyGPS::GPS_INVALID_F_ALTITUDE ? 0.0 : alture;
//Serial.print("Location: ");
/*Serial.print(latitude, 6);
Serial.println("");
Serial.println("");*/
if (chars == 0){
// if you haven't got any chars then likely a wiring issue
Serial.println("Check wiring");
else if(secondsToFirstLocation == 0){
//still working
Message 17 of 49
(2,269 Views)
Really thanks for everything man, really thanks!
Message 18 of 49
(2,262 Views)
You need to right the linefeed character wherever you send a response.
If you wrote the Arduino code, then YOU should know how to do it.  I don't do C code.
In basic it would be something like print#1, chr$(10)
Message 19 of 49
(2,261 Views)
Thanks man for everything, i'll try it, realyy thanks I never see this code works like this! Thank you so much! 😄 And excuse me that I don't understand some directions, I don't understand English very well, but i'm doing it, Thank you again man.
Message 20 of 49
(2,258 Views)
