Lecture/Ecriture de Bit d'un mot via Modbus depuis/vers Schneider API || Read and write bit of word via Modbus from/to(towards) Schneider PLC
Bonjour et merci d'avance. J'ai un problème pour lire ou écrire un bit depuis ou vers un API schneider.
J'utilise Modbus comme protocole de communication.
Pourriez vous m'orientez vers une solution.
Hello and thanks by advance. I have a problem to read or writ a bit from or to(towards) a schneider PLC.
I used Modbus protocol of communication.
Could you point me to a solution.
(1,863 Views)
Hi David,
Which problem do you have?
What have you tried?
Which Modbus library do you use?
Which "bit" do you want to access?
Mind to attach a manual for the specific register you want to access?
Point to solution: read the manual of your PLC…
(1,857 Views)
Here's some reading to get you started:
An introduction to Modbus
The Modbus Organization homepage has lots of information
The LabVIEW Modbus API discussion group
You will also need the proper manual for your device as it will have all the Modbus register information and details.
=== Engineer Ambiguously ===
(1,842 Views)
Hello, i would like read or write in the bit of word.
I used NI Modbus Library 1.2.1.42   .
For exemple if i have in Schneider PLC an address of registers for a word at @ %MW2245, i would like read a bit as that 2245.0 or 2245.1 or 2245.2 or .......
I don't know how to do for this.
(1,831 Views)
Accepted by topic author DavidFrance44
That notation (2245.0 or 2245.1) means Holding Register 2245 Bit 0 or 2245 Bit 1
Read the holding register and convert the (Unsigned Integer) output to a Boolean Array
(1,820 Views)
Thank you i see this , in this evening.
Have a good Day.
(1,813 Views)
