Led light
how do we make a push button turn an indicator on and afterwards a sensor will turn it off?
(3,638 Views)
What type of sensor you want?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,632 Views)
A motion sensor.
Let me explain the process. in a automated car wash process.I have to press a confirm button which is latched when released and this confirm button will turn on a light that has to turn off when a motion sensor located at the exit will turn the light off. Please help.
(3,630 Views)
How you are going to read the motion sensor?
When you got the valid data, you just need to read the data inside while loop and turn it off accordingly
--Ranjeet
(3,627 Views)
Hi Majd,
use a shift register to keep the current state of the LED. The rest is quite easy as shown in the pseudocode:
IF buttonpress THEN LED=TRUE
IF sensorsignal THEN LED=FALSE
(3,621 Views)
