Led
      Here is a simple question,but Iam not getting the expected results.I have a numerical array with values as zeros and ones only.I want to display them in an LED array with one-LED ON and zero-LED OFF.Attached is my VI.please help.That is for one values the LED will glow and for zeros the LEDs will be OFF.
(3,787 Views)
Accepted by topic author josy
Hi josy,
try this:
Or that:
(Avoiding RubeGoldberg comments 🙂 )
(3,773 Views)
Here is one way to do it. It's not the best way to do it, but it gives you the result you ask for. Try getting the same result with a differet approach. For instance without the for loop, like GerdW's second solution, which is the best.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,771 Views)
The function Number to Boolean array takes the number, converts it to binary then creates an array.  Your VI will output the binary representation of the last element in the numeric array.  What you need is something like this.  It assumes that the entries are either >1 (True) or zero (False)
Ken
(3,766 Views)
Ken
And the reason you have a while loop is because?
(3,750 Views)
The original problem was in a loop and I just modified it!  On review it [the loop] is a bit (!) redundant
(3,746 Views)
     Thanks for reply.
(3,700 Views)
