Left and Right Audio Channels Examine
Hello everyone, i have the following setup, on one computer i have a tone generator Vi, that generates tones in differents waveforms and frequencies, and on the other computer i have this sound examine Vi, i connect them via AUX, in generator i plug in the headphones jack and in the sound examine i plug in the microphone jack, everything works great, the waveforms are clear and all, but im getting on the graph both the left and right audio channel, is there a way to get the left and right audio channels from two different sources, mostly because i want to use a summator and do some modulation, the source of the information is from the microphone.
Here is my Vi.
(3,397 Views)
Accepted by topic author Daixman
Your answer is in the express VI.
If you do it manually, you will be able to separate them easily.
You also can use index array to separate them. 😉
Benoit
(3,355 Views)
Thank you, i toltaly forgot that i can array index the stereo input, it worked!
(3,350 Views)
