Let autoscale ignore certain plots
Hi all,
I want to let Autoscale ignore certain plots.
The idea is to add dashed lines at 0 100 400 and 800, so I added plots with the these constant values.
But I don't want the autoscale to keep at 800 if any real data is way below this value, because this reduces my "resolution" of view.
Any idea how to do this?
Thanx
(2,581 Views)
Accepted by topic author Bart_Aerts
You can disable autoscale, and use proprty node to change max scale automatically.
(2,575 Views)
Good idea, thanx 🙂
(2,570 Views)
