Lev-Mar non-linear fit problem
Hey Altenbach,
Could you please save the "fits.zip" file you have provided me in version 8.5.1 or lower and post it again ? It would of great help ....
Thank you,
Marky
Message 21 of 25
(908 Views)
Hi Marky,
                You can post it in Version Conversion Board
Thanks as kudos only:)
Message 22 of 25
(904 Views)
Thanks Danil!
Message 23 of 25
(882 Views)
@Marky1987 wrote:
Note : Can you please check the results with  the fits : "y = a0*sin(2pi*f*x+a5) + a1*sin(2*2pi*f*x+a6) + a2*sin(3*2pi*f*x+a7) + a3*sin(4*2pi*f*x+a8) + a4*sin(5*2pi*f*x+a9) " and y = a0*sin(2pi*f*x+a5) + a1*sin(3*2pi*f*x+a6) + a2*sin(5*2pi*f*x+a7) + a3*sin(7*2pi*f*x+a8) + a4*sin(9*2pi*f*x+a9)
They give me different results??
You are quoting two different formulas, with different terms and different parameters. Of course the result will be different!
Message 24 of 25
(870 Views)
Hey Altenbach,
In the two equations I have mentioned only the harmonics of my sine function  are changing(the red marked integers)...
1) True that , when the intergers changes there will be a variation in the amplitude..
2) But here the  " fit "  with the first equation is so bad and the second equation is good..
So I just wanted to check with you if you notice any bad design of the equation I did (for example : previously adding a knob to the template function)  which gives wrong values to my fit?
Message 25 of 25
(858 Views)
