Level change indicators
Hello Experts in the house. Salutations. I am a graduate student conducting experiments that require me to detect really small water level changes at approximately about every 10mins. The whole gist is I have certain polymers that absorb water through a membrane, and i need to know how much water is absorbed. My design setup is such that i can see the water level decrease from my little 3d printed tank. I know i can relate water level reduction to volume of water absorbed by my polymer. I have found a water level sensor on amazon which i shall attach the link here. My question is , this particular indicator specifically states it works with an arduino board, and i would like to use mydaq board. How do i achieve this.
https://www.amazon.com/gp/product/B06XHDZ3Q4/ref=ppx_yo_dt_b_asin_title_o00__o00_s00?ie=UTF8&psc=1
I thank you in advance for any help rendered. I would be monitoring this platform for answers.
(3,228 Views)
Judging from the sparse technical information I'd say:
Connect a stable 5V supply to Plus and GND Pin of the sensor. Perhaps myDAQ has such an output, but I'm too lazy to search for the documentation.
Then connect the S-Pin to one of your Analog-Ins of myDAQ, and the GND-Pin to an AI-GND-Pin.
Regards, Jens
Kudos are welcome...
(3,215 Views)
Thank you for the quick response. This seems like it would do the job. Would the displayed values be in voltages, and if yes, do i need to calibrate to get a relationship between voltage and water level.
Best
(3,212 Views)
Judging from the link provided in the Q&A of your amazon link (off-topic: as a grad student you should have been able to follow that link yourself) you'll get an uncalibrated signal in volts (range 0 to V_supply).
And let me state, I am in high doubt that this sensor is capable to detect small level changes accurately.
Regards, Jens
(3,200 Views)
Thank you for all your help. I thought as much, but its worth a trial.
(3,193 Views)
