Levelliste CW-Plot
I am using CW 3D Graph (LV 7.1) to show contourplots. I would like to write values in to levellist. I am using methods to do this. In attached VI you can see how I tried to do this. But unfortunately it does not work. I have no explanistion why I am not able to write the values to levellist in this way. It seems to be the only way for me. Do you have any idea any experiences and can help me with this problem.
Let me know if you need further information.
Your support is really appriciated.
Yours
MEE
(4,127 Views)
HI MEE,
I have never attempted to write to the level list (or knew it existied!) so I threw together this example after trying this out myself. Smiley Wink
In the attached (LV 7.1 version) I first graph the data and then emulate what I would do if I was interacting with the CW 3d graph properties. I select a plot, then the contours for that plot. Any previous contours are tossed before I write to the Levellist. As a general rule, I try to figure out to do thing first with the CW 3d properties screen and then code based on that structure. It get me close and then I have to do some educated guessing. Smiley Surprised
Have fun,
Ben
Message Edited by Ben on 01-15-2006 10:39 AM
(4,130 Views)
Excellent !
Chilly Charly    (aka CC)
(4,111 Views)
Hi Ben,
Thank you very much for your reply. That was exactly what I was looking for. Thanks again!Smiley Happy
(4,054 Views)
