Levenberg-Marquardt and parameter bounds
Hi everybody!
Is there a way to set "parameter bounds" when using Nonlinear Curve Fit LM with Formula String? ( I can't use the nonlinear fit with f(X,a))
thanx
(2,733 Views)
If I understand correctly, I think you should use the Constrained Nonlinear Curve Fit VI if you want to set parameters bounds
Also some similar thread was treated here .
Hopefully this helps.
Message Edité par Steve Mohamed le 01-28-2009 04:23 PM
Steve M.
(2,703 Views)
