Levenberg-Marquardt, error
  • You should not call it Levenberg-Marquardt if that has nothing to do with it.
  • You need to specify that it depends on my example code, downloaded from elsewhere.
Message 11 of 12
(1,448 Views)
Excuse my sloppiness.
This version right here contains an example where Nonlinear Curve Fit  VI (Levenberg-Marquardt) doesn't work, as described above. However, using the Simplex (Nelder-Mead) method as suggested by altenbach, the fit works perfectly fine. The user can choose between the two algorithms.
The original version of the Nelder-Mead VI can be found here: Nelder-Mead VI by altenbach
Hobgoblin
Message 12 of 12
(1,434 Views)
