Levenberg-Marquardt - termination?
  • Feed the current tick could via the data variant input when you call the nonlinear fit.
  • Inside the model function, take a tick count and subtract the tick count from the data variant.
If the difference is > 5000, generate an error inside the model and the fitting procedure will stop.
Let me know if you need help with all that. 😉
Message 11 of 26
(1,819 Views)
Hi altenbach,
Thanks very much.
I am unclear about the logic of your suggestion.  Isn't my model function called once for every iteration of the L-M algorithm?
Will this work?
How do I generate an error inside the model function?  It has no error clusters.
Thanks again.
Message 12 of 26
(1,810 Views)
Actually the L-M VI has an error out cluster.
Still unsure about the logic of your suggestion.  Please explain.
Message 13 of 26
(1,807 Views)
This arrangement terminates too early.  The two tick values are almost identical but when I subtract them I get a huge number which is obviously much greater than 5000.  Please have a look and let me know what I'm doing wrong.
Notice my model function contains an infinite sum (while loop).
Message 14 of 26
(1,803 Views)
Switch the inputs of the subtract function. 🙂
(You need to subtract the "new tick count" from the "start tick count", and not vice versa.)
Message 15 of 26
(1,801 Views)
Sorry, said it wrong: You need to subtract the "start tick count" from the "new tick count", and not vice versa.
Message 16 of 26
(1,797 Views)
OK, this is probably a problem. Since you are terminating the inner loop based on a tolerance, the partial derivatives calculation will probably be suspect.
The model calculation as a function of parameter value is not a smooth function but will look more like a stair steps. You should probably calculate your own partial derivatives inside the model function to deal with this.
Message 17 of 26
(1,794 Views)
How to calculate/implement the partial derivatives?
Do I have to do it analytically?  That could be a problem 😉  Can I do it numerically?  If so, how??
The function appears to return a correct fit of the parameters although there are numerous occasions when it can't solve and/or returns huge parameter values.
Thanks for your assistance.
Message 18 of 26
(1,773 Views)
Isn't this the same function you asked about earlier?  If so I tested it out with this fit function VI.  I think you get something like 7 times more function calls when you use finite differences.
Message 19 of 26
(1,769 Views)
Thanks Darin, I appreciate that.
Can you please explain in more simple terms what you've done?
It looks like you may have implemented the partial derivatives (numerically?).  Did you work them out analytically?
I need to verify what you've done.
Message 20 of 26
(1,764 Views)
