Levenburg Marquardt does not give same results as purchased Curve fitting software
I am trying to create a curve fitting application in labview that will loop through a number of formula and fit for each formula.  The user will then be able to select an equation based on the R-Squared value.  This is similar to an old software the we have called Table Curve.  However I am have trouble getting one formula to work properly.  What I did was enter a data set into Table Curve and let it do it's thing.  Attached is output from Table Curve. I have also attached a simple vi  that I can manual enter the data and formula string into.  I do not get good fitting results even if I enter the data from Table Curve.  Could somebody please have a look and offer some assistance?
Terry.
(3,060 Views)
Double-check your X and Y inputs.
(3,050 Views)
Terry,
I cannot look at your VI now, but looking at the curve you posted raises some questions.
The curve shows only four points. The coefficient b is 5 orders of magnitude smaller than a or c.
Is this enough data to actually fit meaningfully to such an equation?
Is the data sufficiently precise to generate coefficients over 5 orders of magnitude and mean anything?  If one of the data point has 0.01% error, does that change the results?
What happens if you drop the b term out of the equation?
Lynn
(2,997 Views)
Thanks for the reply. I originally made this application using an older version of Labview. When I made the sample vi to post I am using a newer version of Labview and the X and Y input positions have changed. This still makes me feel kind of foolish for not picking that up.
However I still have a question.  As I have indicated I am trying to reproduce an older Curve Fitting program.    In the original program the x and y data is entered and when a button is clicked a list of models with corresponding R_Squared values is displayed in less than .1 second.  I am assuming that the software is going through all the models and determining which models work for the data set.
I have copied and formatted all the models from the software and  put them in a separate .txt file that my application uses to fill an array (~5000). Then in my vi I have  a loop  the goes through all the models and generates a list of models that does not produce an error, and has an R_squared value better that .99.  The time to do this takes about 30 seconds.  Do you know of anything that I might do to speed this process up?  Is there something in the original data that I can look at that will quickly eliminate models to use?
(2,990 Views)
What are the models? How many models are there? Do the models differ in the number of parameters? Do you have reasonable guesses for all the parameters?
Parsing a formula is relatively slow. You might want to do the VI model version. Fill a model folder with all desired models, then have the program list the folders, then iterate through all model references, fitting with each.
(2,976 Views)
The X and Y inputs of the LM vi are a constant pain in the neck to me, so that is why I quickly spotted it.  The very first test I tried was to set the max iterations to 0 (you already created the constant for me), and this simply sets the best fit to your initial guess.  Then the issue was evident.
5000 Models will present a bit of a problem.  A few things to think about.  The model you show would be solved in less time by a linear Least Squares algorithm,  great for linear combinations of non-linear functions.  No derivatives or initial guesses to worry about.  Same is probably true for many of the models.  A common mistake is to see a non-linear function and assume that means you need a non-linear LS fit.
When you must use the LM method, try to use a VI (even if it means using a Formula Node), and if possible I strongly urge you to calculate the derivatives.  Probably the best way to get good results in the least amount of time is to provide good initial guesses.  This can be a challenge in an automated process.
Finally, the data set in your example is relatively small, if that is not the case I would suggest you decimate the data and do your trial fitting to a subset of the data.
(2,959 Views)
