LiCor Serial Read Errors - hex 0xBFFF006c
This could definitly be a problem with your seriel port.  Have you been able to test it in Hyperterminal?
Message 21 of 29
(1,894 Views)
Hello! Yes, I am able to test my communication in Hyperterminal and I receive without problems data from my device.
Message 22 of 29
(1,897 Views)
You said you were communicating with a robot, what device are you communicating with (model #)?
Eric
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
Message 23 of 29
(1,875 Views)
Hi Eric,
I communicate a PIC 18F2520 with the LabVIEW 2009.
The communication of the device with Matlab run very good. I don't know why, perhaps because the opening of the port by Matlab works differently than VISA.
My questions too is why the communication in the MAX of LabVIEW doesn't work and I get the same error BFFF006C in the warning box.
Best Regards
Message 24 of 29
(1,848 Views)
Pleace any Idea?
Message 25 of 29
(1,826 Views)
You've been trying unsuccessfully for more than half a month to get an answer from them. It hasn't worked, and it probably won't. You might have to approach your problem from a different dirrection.
Message 26 of 29
(1,824 Views)
I noticed you starting posting in another forum about this particular error.
Error VISA: (BFFF006C) and (BFF006B)
The other forum advised you to run a loopback test on your device, have you done so already? If not, use the following link as a reference on completing the loopback tests.
Loopback Test
Eric L
Eric Liauw
Message 27 of 29
(1,810 Views)
Hi Eric,
I tested already with Hyperterminal and with the MAX of LabVIEW. On Hyperterminal I receive data without problems but on the MAX I get the same error BFFF006C.
I tested already too with a example of LabVIEW and I get the same error.
Ricardo.
Message 28 of 29
(1,800 Views)
I had this problem. Increasing the TimeOut setting solved that problem.
Suitable BufferSize might be adjusted as well.
Message 29 of 29
(1,714 Views)
