Library deployment failure - 2147220712
Hello All,
When trying to deploy a library(in a project) with a shared variable on to 'My Computer', its failing for some reasons. Please see the below extract.
using LABview 8.6.
Initializing...
Calculating dependencies...
Checking items for conflicts. This operation could take a while...
Preparing items for download. This operation could take a while...
Deploying My Computer
Deploying test.lvlib\\xx.xx.xx.xx\test deployment failed (error: -2147220712, (Hex 0x80040318) Internal error: The client has failed to connect to the configuration server, possibly because the server is too busy or has run into a communication error. Please note the steps you performed that led to this error and contact technical support.).
Deployment completed with errors
Any thoughts about the above report please?
Message 1 of 8
(5,791 Views)
Message 2 of 8
(5,781 Views)
How can I make sure that all the NI software is up and running in my scenario(if that is the case)? Is there any particular process or windows service needs to be checked? However all the NI windows servcies are up and running under service manager. Also, I can run other VIs without any issues as usual. I could not figure out where I will fit from the above given link. Can you please eloborate, if you have any particular point?
Thanks for your time.
Message 3 of 8
(5,766 Views)
Could you post a view of your project? What targets are communicating with one another? Are you working with RT devices? What Operating System are you working with?
There are a number or NI Services that provide communications behind the scenes: NI Service Locator, NI Configuration Manager, NI Variable Engine, to name a few. Are these services started? If you attempt to restart them, are you confronted with any errors?
With a new empty project, and library containing a single variable, can you deploy it? Do these processes show up in distributed system manager? Can you create processes in Distributed System Manager? (Tools >> Distributed System Manager)
Thank you for your time, I look forward to your responses.
Patrick Corcoran
Application Engineering Specialist | Control
Message 4 of 8
(5,737 Views)
Hi Patrick,
Enclosing the project here for your review. I am on Win XP ver 2002 SP3, all I am trying to do is publish the shared variable so tha I can access from a different computer on that network. Above mentioned and all other NI related services are up and running fine. I am unable to deploy a single variable and so is the process under Distributed System Manager.
Message 5 of 8
(5,721 Views)
Just a shot in the dark, but do you need to have database logging enabled in your .lvlib?  I have found that by the time I get around to library deployment, all NI services are up and running.  I have noticed that I may need to wait for NSV's to become transactional after library deployment.
Message 6 of 8
(5,701 Views)
It appears that NI Variable Engine is not functioning correctly on your system. Do you have customized firewalls, or antivirus software that is denying network communication between software on your local host? NI Variable Engine, and the both services, may need to be specifically allowed through the firewall, to properly host network objects.
This error code is curious, as it typically pertains to communication to the DAQmx Driver, as alluded by muks. Did anything recently change with your LabVIEW installation, a new driver or toolkit? Have you seen any additional environment behavior problems?
Patrick Corcoran
Message 7 of 8
(5,680 Views)
Hi Patrick,
I may suspect on that angle if you motivate so, as I experienced firewall isuues in the past on the PC currently I am on. Will try on a different PC that has got lenient security&n/w settings etc.
Thanks.
Message 8 of 8
(5,660 Views)
