License for code found in this forum
I'm using this forum since a couple of years and I'm now using the code/llb/VIs that I found in my applications.
I'm wondering what is the license for such piece of code?
Is there any generic license to use?
I've LabVIEW2012 PDS and create executables based on these VIs.
For instance :
http://forums.ni.com/t5/Community-Documents/DirectShow-NET-LabVIEW-SDK-Video-Audio-IP-streams/ta-p/3...
or
http://forums.ni.com/t5/LabVIEW/Using-Packet-Sniffer-Project-WinPcap-example/td-p/416826
Thanks in advance for your support,
Bim
Message 1 of 8
(3,741 Views)
When you registered for the forums you accepted an agreement "Terms Of Use".  Essentially, everything up here is treated a free source.
Message 2 of 8
(3,728 Views)
Many thanks for this confirmation and linking to the terms of use of the forum !
Bim
Message 3 of 8
(3,724 Views)
"Free source" but "only for your personal, non-commercial use" ?
Message 4 of 8
(3,507 Views)
"nothing on the Site shall be construed as conferring any license or right under copyright, trademark or other intellectual property rights. "
I interpret that as free to use.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(3,489 Views)
Hi Yamaeda,
Thanks for your feedback, I'm still not sure if I can use, integrate and distribute applications using code found on this site, even if provide as examples or demo purpose.
Terms of use are not so clear, even if everyone seems going your way (and I'd like too).
thanks & BR,
Bim
Message 6 of 8
(3,473 Views)
@bim4 wrote:
Hi Yamaeda,
thanks & BR,
Bim
Read the TOS.  We're not lawyers, so we cannot interpret it for you without opening ourselves up to lawsuits.  If you have questions, either direct them to NI or directly to the user that posted the code of interest.
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(3,462 Views)
Hi Billko,
I understand your position, I'm currently doing parallel requests to the developer of the code and to NI.
Thanks for your support,
Bim
Message 8 of 8
(3,448 Views)
