Lifa_base.pde
 Hi! When I download the file LIFA_base.pde in the arduino Leonardo there was a mistake. How to fix it?
(3,391 Views)
From the screen shot I would say get a chip that is supported.  You may have the wrong board type selected in the Arduino IDE.  Select the rigth board in Tools >> Boards.  On top of that make sure the correct serial port is selected.
(3,388 Views)
all this is in order! The fee is chosen correctly and the port too. And that's when testing code falls out these errors.
(3,385 Views)
You mention you are using an Arduino Leonardo but I've seen no documentation that states this board is supported.  Only Uno, Dimuelanove w/ ATmega 328, and Mega 2560 appear to be supported.
(3,369 Views)
