Lifetime of disconnected (VLM) license
We issue disconnected licenses for our users via the NI Volume License Manager (VLM).  It is possible to create a disconnected license that expires after the contract date.  If a disconnected license is created this way, will it actually work beyond the contract date (that is embedded in the disconnected license file, by the way)?  This is what is implied by information I could find, but I'd appreciate a solid yes or no.
(1,542 Views)
When I create a disconnected license it asks when it should expire.  We just make it set to expire when the license expires which for us is at most 1 year.
I do believe if you set it to never expire then it will continue to work after that date.  But you obviously can't use the newer versions of LabVIEW that have come out since then.
(1,464 Views)
IF by "the contract date" you mean your SSP (service and support contract), if you have a perpetual license, the SSP is not in any way related to whether the disconnected license expires, since the right to use the softtware extends past the expiration of the SSP. Since this is a 2021 thread, I'm assuming that is the case.
IF by "the contract date" you mean you purchased software after NI went to subscription-based licensing, then the license expires when the subscription expires (and so does the right to use the software) regardless of whether you are using a disconnected license, node-locked license, or VLM-based floating license.
(577 Views)
