Light current
Hi all, I need to change the IL (light source) [see attachment], it is not directly connected to the substract. In fact IL is a function of ( light intensity, the material, & efficiency). We should consider it at 1kw/m2. Please consider silicon type of material. How can this be done. Can you write the example for me. Thanks in advance.
(3,453 Views)
Heres is the attachment. Pls help me.
(3,451 Views)
Please stick to your original post. You are already receving quite lot of help there (Zach is basically writing the code for you).
(3,447 Views)
It is also starting to sound like this is homework..........
(3,427 Views)
That much is obvious, and the poster actually says so explicitly in the other post. I think Zach provided a little too much homework help in this case, but that's Zach's prerogative.
(3,419 Views)
