Light up a boolen
altenbach wrote:
(Sorry, I really never use dynamic data much, so I I am not really sure how single boolean outputs are handled when connected to dynamic data)
Seems you would simply get the result of the first point contained in the dynamic data.
Message 11 of 13
(579 Views)
Your case structure is still not needed. Delete it!
Now you are simply comparing the RMS. That's OK if this is what you want. I cannot make that decision for you. 🙂
(As I said, I don't have DAQmx installed, so I cannot see what kind of dynamic data you have. I guess you are recording only a single channel.)
Message 12 of 13
(578 Views)
Hi altenbach,,
    you are right, case structure is not at all required.
Message 13 of 13
(574 Views)
