Limit on how fine graph with autoscale
Hello all,
I am working on a temperature controller, and I currently have a graph set up to show the temperature over time. The autoscale feature works great, however, if I let the temperature sit for too long, the y-axis autoscale becomes so fine that it appears that the temperature is fluctuating massively and looks pretty ugly. It gets in a range of +/- 0.2°C.
Is there some way that I can limit how fine the autoscale can go? For example, create the following restriction on the y-axis scale:
Ymax – Ymin >= 2°C
Thanks for any help!
-Clint
LV version 6.1
(2,476 Views)
Just turn off autoscaling and set the scale min and max using property nodes at appropriate times.
Now you have full programmatic control of the scaling. 😄
(2,473 Views)
