Limit value test for fields 1 to 3 in a graph
Hello, everybody,
I am currently working on a measurement system to detect and evaluate the current of motors in case of faults. For this purpose the displayed measured values should be evaluated in a graph in e.g. 3 different fields. A limit value test for fields 1 to 3 in a graph, which should be displayed differently. Finally, a positive or negative output of the measured value analysis should take place.
The measurement system itself already exists, but I have problems to integrate the mentioned 3 fields for analysis.
The problem is, that e.g. with the VI's "masks and limit test" the memory fills up quite fast and the program cannot be used any more. If I try to solve the setup with Minimal Vi's, I get the error -20337 again and again, for which I can't find a solution.
Maybe one of you has an idea or a hint how to create or approach the required check.
Thanks in advance for your help and ideas.
Message 1 of 1
(1,888 Views)
