Limited PID gain to 127 for FPGA
i have tow questionq the first is technical the second is commercial.
1* For an FPGA application with PXI8108 and PXI-7841R i want to insert a value of "2100" so higher than 127 but pid module gain is limited to 127.
How can i do. thanks for your help  😕
2* I want to buy another  product like FPGA target PXI-8108 for others application but i need only PXI7841R with LABVIEW FPGA and RT i d'ont need to other complementary modules to insert . The chasis it's neccesary ?
I can not find other versions like PXI7841R do the same job with the same performance with PC but less expensive (without chassis & PXI-8108)  ? i'am looking for in NI site,but i did'nt found so can you propose me some NI desired product
thanks for all your responce.
Riadh ABDELHEDI.
(3,556 Views)
Accepted by topic author Rayden
2) The chassis has the RT controller. You can get R-series FPGA cards (no RT) for USB / PCI / PCI-Express which would plug into a regular PC. You can install LabVIEW Real-Time on a PC but it requires certain hardware configurations for it to be supported. Have you  considered a RIO device like a CompactRIO / sbRIO? These are small form-factor embedded NI devices that have an RT controller and FPGA and are lower cost than the PXI-based solution.
(blog)
(3,545 Views)
The PID FPGA that you are using is fixed-point and the maximum available is 127. If that is the proportional gain, than you can always multiply 16.5 the output, to obtain the additional gain. Or prescale the setpoint/process variable to this amount too.
If you have access to LabVIEW FPGA 2015, we have a floating-point PID that would allow you to use any value that you'd wish (within the single datatype).
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,522 Views)
I use Labview FPGA 2014.
Can you explain more please... i see many solutions but what i must do exactly to put a value over 127.
Thanks.
(3,511 Views)
@Sam_Sharp
I have a budget of 1500 euros what can i buy as Compact RIO model to developp application about control power electronics converter,some others E/S...
thanks to sugess me some commercial links.
(3,483 Views)
This is a conversation you should have with your local NI Sales Representative - call your nearest office and discuss with them as they can select the right product for you given your budget.
Without knowing your exact input/output requirements I couldn't possibly select something - a Single-board RIO (e.g. 9636) or cRIO (9066 or 9063) with a few modules might be the best things to look at.
(blog)
(3,467 Views)
