03-09-2016 11:04 AM
Hey all,
Ok, this should be simple... I've done the search and looked in the Help files, but didn't find what I'm looking for... I want to limit my File Path to a single type of file, in this case I only want to see Excel sheets in a folder. I have the default folder set, but finding what I need... anyone got a hint? 🙂 TIA!
Chad
Solved! Go to Solution.
03-09-2016 11:05 AM - edited 03-09-2016 11:05 AM
There is a Pattern input to the File Dialog. This can take ina string like "*.xlsx" and will find all filenames with the extension "xlsx"
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
03-09-2016 03:59 PM
Thank you sir!
Much appreciated!
