Limiting Number of Times an Event can be Called
Is it possible to limit the number of times an event in an event structure can be called?  For example, if I have an event called "Initialize", I only want that event to be ran once.  After this Initialize button has been pressed, is it possible to prevent it from going into this event if the user presses the button a second time?
(4,200 Views)
(4,193 Views)
You can also keep track of the number of times an event has been triggered, and use a case structure to not execute the code in the event case if that counter is too high.
(4,184 Views)
Accepted by topic author _natalie_
It's trivial to do this.  In the initialize event, disable the initialize button with the "disabled and greyed out" input to the appropriate property node.  Then, the button can't be pressed and you won't trigger the event again.  If things in the application change such that you'd want to use it again, same property node with "enabled" as the input.  Prior to your code running, set up a property node to enable it so that your user always has access to it when the VI starts.
(4,173 Views)
This assumes that the event is a "value changed" event. I have seen plenty of beginner code using "mouse down" events for buttons and these would still trigger, even if the button is disabled. Just a warning. 😄
(4,163 Views)
Fair.  Let's make a modification that results in a still trivial solution.
1) Check the event to ensure it's a value change event.  If not, change to value change event.  If so, do nothing.
2) Continue to prior solution
(4,154 Views)
Thanks so much!  Very easy solution.
(4,087 Views)
