Lin Frame
      I have a .log file. I wanted to know how to read these Lin frames from  .log file in Labview? these are temperatures measurement. If there are any examples pls do post.
Message 1 of 8
(4,162 Views)
You have about 10 columns of various formats (time, text, hex, etc).
Which column is the temperature data? Do you have a document that describes the formatting?
Message 2 of 8
(4,149 Views)
jay090909,
I'm assuming you are using Local Interconnect Network and have seen this:  https://www.ni.com/en/shop/seamlessly-connect-to-third-party-devices-and-supervisory-system/introduc...
Are you using any NI hardware when getting this data?
-SS
Message 3 of 8
(4,143 Views)
       I don't have any document wrt this case, but as i saw few documents in internet i feel it might be like this pattern.
   511:26:27.953                  00000029                  LIN Full Frame       4                    94   46  00  03
     Time stamp                    Frame id                                               bytes                   Temperature Data.
Message 4 of 8
(4,141 Views)
Do you know what kind of temeperature ranges you expect in the file? Are the lines with only 2 bytes something else?
Message 5 of 8
(4,123 Views)
       The temperature ranges are from 80°c to 100°c . There are only 2 bytes of data, notging other than that.
Message 6 of 8
(4,104 Views)
Try this. No guarantees.... You really need to get the full file format specification Anything else is just guessing.....
Message 7 of 8
(4,102 Views)
    Thanks a lot, I'll try to get more info regarding full frames.
Message 8 of 8
(4,099 Views)
