Line + Scatter on 3D graph
Thank you for the prompt reply! I tried to run your program and encountered two errors- at invoke node and wiring- at two spots. I have attached screenshots of these errors in attached image.
Ramesh
Message 11 of 14
(790 Views)
Never mind, I had to change set Drawable to set Geometry. It works!
Thanks again!
Ramesh
Message 12 of 14
(788 Views)
Hi, I'm now doing almost the same thing, I want to merge 3d quiver and 3d line onto 1 display, is there any way to do this? it seems the 2010 replys didn't give any clear answer. thanks in advance.
yhs
Message 13 of 14
(647 Views)
Take a look at the following article which discusses plotting multiple 3D plots on one graph:
http://digital.ni.com/public.nsf/allkb/0ABACC8B023C15D3862572ED0070E4A6
Notice that there are also links in the Related Links section that will open up examples.
Also, a lot of times you will get more replies to your post if you start a new thread.  Since this one has been open for several years, fewer people will see it.
Message 14 of 14
(623 Views)
