Line grouping in data acquisition
What is the difference between one channel for each line and one channel for all lines selection in line grouping for daqmx create channel digital output.
Message 1 of 8
(3,862 Views)
Determines how you write data to DAQmx Write API
Santhosh
Soliton Technologies
Message 2 of 8
(3,829 Views)
Can you please give detailed explanation with example
Message 3 of 8
(3,825 Views)
Hi Manik,
Drop a DAQmxWrite function in your block diagram and look at those 6 options you have when selecting Digital->Multiple Channel->Single Sample->"...". Now think about how "one channel for each line"/"one channel for all lines" relate to those options!
When handling multiple digital channels I prefer the "port" options...
Message 4 of 8
(3,808 Views)
Actually I can understandthe single channel>single sample. But I am unable to relate this with line grouping. Can you tell in what occasion I have to choose one channel for all lines and one channel for each line with some example and Discrription Thanks in advance
Message 5 of 8
(3,777 Views)
Accepted by topic author Manik981211
Hi Manik,
"One channel for each line" relates to using boolean arrays, with one element per channel.
"One channel for all lines" relates to using U8/16/32 data, with each bit in the unsigned integers relating to one digital channel.
You don't "have to", but you "can" choose which datatype suits your requirements. Keep in mind: using boolean data in LabVIEW will increase memory requirements (8 times) as each bit is stored/handled in memory as a byte. Using unsigned integers is more memory efficient, but you need to learn how to set/reset single bits in those U-INTs…
Message 6 of 8
(3,770 Views)
I tried to find the difference between digital 1d and 2d boolean n channel 1 sample in labview help, I noticed each channel in the task can contain 1 digital line(1d) and the channel contain one or more digital lines(2d). But when I simulate this two, it seems to be work like same.can you explain why?. And also I didn't get any error.
Message 7 of 8
(3,761 Views)
I understand the concept. Thanks
Message 8 of 8
(3,754 Views)
