Linear Fit errors
I am trying to make use of the "Linear Fit" and "Linear Fit Coefficients" vi's, but I am getting errors despite inputting what I thought was correct. If I connect my two 1D data arrays to the 'X' and 'Y' input terminals then I get the error -20002.  If I connect empty arrays, I get the error -20006.  I'm leaving all the other inputs unconnected.
In looking for a solution to this, I came across something altenbach said a few years ago:
@altenbach wrote:
Some possible errors that can occur with linear fit (but they would generated different error codes):
  1. You have only a two-column file. In this case you need columns 0 and 1 (column 2 does not exists) error -20002
  2. You have only one row, thus only one data point. error -20006.
I only half-understand what he meant, and/or how it would apply to what I'm doing wrong.  Can anyone help me out here?
Never say "Oops." Always say "Ah, interesting!"
(5,602 Views)
Accepted by topic author J.Mamakos
Please attach code.
-20002 states that the input sequences must be the same size.  So X and Y need to be the same length.  Verify this first.
-20006 states that the input lengths must be at least 2 elements.  So passing in empty arrays makes perfect sense here.
(5,593 Views)
One of my arrays was an element short (I was taking the arrays from different ends of a For loop).  Thanks for showing me where to look!
(5,589 Views)
Most of the time, a simple error lookup will tell you exactly where you went wrong.
(5,586 Views)
I didn't know you could do that (aside from looking on the internet).  I've found the "Explain Error" option now that I look for it.  Thanks again!
(5,583 Views)
