Linear Fit not run with NaN
Hi guys.
I am trying use Linear Fit to made the best fit of temperature acquisition, but during the acquisition i acquire some NaN data.
I can plot the temperature graph, but i cant plot or receivo soma data from Linear Fit.
My code is below, in LV2010.
Can anyone help me?
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
(4,721 Views)
You simply need to remove all nan's from the data. There are plenty of examples in the forum.
(If you could upgrade to a newer version, the conditional tunnel would make things even easier.)
(4,715 Views)
I try remove using the examples which i found, but i dont have sucess.
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
(4,709 Views)
Then show us your code.
(4,703 Views)
Follow my VI.
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
(4,700 Views)
Accepted by topic author Kossmann
You are almost there. Remember you also need to remove the matching X values to keep both input arrays the same lenght and aligned. Simply process the X array in the same loop using the same case structure, just using a second shift register.
(4,689 Views)
Thank you
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
(4,630 Views)
