Linear Stage Control Using PI (XYZ system), Servo Motors , Controller Mercury C663.12
Hello ,
I am currently making a XYZ system , which only needs position control and axis control , for the system . we use PI Linear Stages to make the XYZ configuration and also use the Mercury C663.12 as the controller for the Servo motor . It has been connected using the USB -daisy chain and we are able to move the Stages using the PIMikroMove Application from the company it self. I am unable to do it using the Labview VI that they have provided and am unable to understand why . I will attach the 3 VIs that i need to be on the same panel . I think i am going somewhere wrong with the reference maybe . But I really need some help with this .
Kind Regards,
Shreyas
Message 1 of 1
(791 Views)
