Linear encoder in LABview
I've managed to get three seperate sine waves out of my encoder. At this point i'm wondering what i have to do within labview to translate these three sine waves into some sort of position indication.
Here is some information:
The DAQ card that I have is a PCI-MIO-16e-1 The linear encoder that i'm attempting to use it a RSF Elektronik MS 6x i can't find the data sheet for the exact model but i've attached a pdf which talks about the variouis signals that it outputs. Also the table below is a table that I found in the documentation for the MS 6x that I have which explains the various pin outputs of the encoder. I hope this help please let me know if you need any further information.
Pin                   Signal
1                      +5 V        Supply
2                      V Gnd              Analog ground              Output 2,5 V typical
3                      R1                    Analog voltage signal
4                      A2                   Analog voltage signal                2 Vss typical
5                      A1                   Analog voltage signal                2 Vss typical
6                      0V
(2,796 Views)
Duplicate post
André (CLA, CLED)
(2,779 Views)
