Linear fit
Hi
Can any one help me how slope of a linear curve is calculated in linear fit vi.
i calculated based on simple math formula but im not getting how linear fit vi is calculated.
i attached a vi, Please help in solving this problem.
Thanks and Regards
Ramesh
(5,208 Views)
Hi Ramesh,
when you think the linear interpolation is bad you should plot your data and the curve:
(black: your data, red: linear interpolation)
Why do you think a linear interpolation would give "good" results with your data?
See my attachment…
(5,181 Views)
Fitting a function (like a straight line, a "linear fit") to a set of data involves creating a model that describes a relationship describing the data, some (statistical) assumptions about the distribution of errors in the measurements, and a fitting criterion for "what is the best fit?".
A common model, set of assumptions, and criterion is (model) there is a linear relationship between X and Y, (assumptions) X is "known" and Y is "measured", with some (often normally-distributed) variation about the "true" value, and (criterion) you want to find the value of Y (as a linear function of X) that minimizes the squared deviations between the measured Y values and the Y value predicted for that value of X.  This is usually called the "Method of Least Squares".
Given a set of (assumed precisely measured) X and (assumed measured with error) Y values, it is an easy calculus exercise to derive a formula to calculate the Y intercept and slope of the line that fits the data in the "Least-squares" sense.  This (should be) what the Linear Fit routine returns to you, particularly if you use the default "Least Squares" fitting method.
Bob Schor
(5,169 Views)
Hi GerdW,
Thanks for your reply.
The data which i linearly interpolated is not the best for my application. My intrest is to find the slope of the curve. the way i found slope in that vi is simple but its is not good for my application.
So im using linear fit vi, but i dint get how they calculated slope.
The modified vi you shared here is helpful.
Thanks & Regards
Ramesh
(5,133 Views)
Hi Bos_Schor,
Thanks for your information that helps me in finding a solution.
I find slope based on some mathematical assumptions and formulae in math's , concepts under least square method. I got the exact results as same as linear fit vi values. find the attached vi for more details.
Thanks & Regards
Ramesh
(5,132 Views)
  • You can remove the FOR loop. it is not needed and just clutters the diagram.
  • I would recommend to use a more sane connector pattern. If you think you need 20 connectors, something is wrong.
  • As has been said, your data is far from linear. Maybe you want to take the first derivative and graph the instantaneous slope at each x instead. What are you planning to do with the result?
  • What kind of experiment is this? Is there a mathematical model that describes the behavior?
(5,121 Views)
