Linear motor: change direction with threshold function
https://forums.ni.com/t5/LabVIEW/Linear-motor-change-direction-with-threshold-function/td-p/4286523
I'd check this link for the other person doing the same homework a very similar project
Message 11 of 15
(1,033 Views)
Post the code, not a screen shot.
Message 12 of 15
(1,038 Views)
It is the code!
Message 13 of 15
(1,033 Views)
Yes, but having the code means we don't have to create your vi by hand to try and help you.
You've also not included the sub vi which deals with resetting your code.
Make sure you include everything which is required for your code to run so that people can assist properly.
in short, you need some sort of logic that reads from the counter value, and controls the T/F state of the direction switch.
Message 14 of 15
(1,026 Views)
@luna30 wrote:
This is an example of the code, I'm using myRio to read the encoder.
Your sequence structure has no purpose because execution is already fully determined by dataflow. Don't add unnecessary complications. You should also know that code with express VIs cannot be analyzed from a picture because all configuration is hidden.
See if this can give you some ideas. As noted in the diagram comments, the logic is incomplete and NOT safe.
Message 15 of 15
(994 Views)
