Linearisation of a signal
Hi ... this is probably one of my last questions for a few weeks 🙂
I have a signal which is not exactely linear.
By measuring the deviations, I could extract key values where I know how large this deviation is. Let me say .. in special areas it is at about 10%.
No I have my signal and my key values. Say: I have B(a) and I need B(b) and I have about 30 key values.
Now I need to create a signal or something (I don't know yet - I hope you can tell me 🙂 ) for exactely the values my signal has.
So my signal has a value of 27 .. but I only have key values for 20 and maybe 50. I need to interpolate this somehow and multiply my value (27) with that interpolated value to get the result ... 29
How would I do that ? If you don't understand what I mean .. please ask 🙂
Thank you
(3,568 Views)
Hi!
If I understood correctly what you need, the Polynomial Interpolation.vi function does the job.
It is in the analyse -- mathematics -- curve fiting group.
You have Y values and X values inputs, where you have to connect the x and y arrays.
Then connect to the x value input the value you wish to calculate.
If this is not what you need please clarify...
Hope this helps,
Paulo
(3,557 Views)
seems like you did Smiley Happy
now that works perfectly .. and even in an acceptable speed ...
thank you a lot 🙂
(3,548 Views)
