Link 2 arrays
Hello;
I am new in programing in LabView and i have a problem with 2 arrays.
I have 2 arrays of 1D and i want to link the arrays but the final array has to be a 1D array.
Example:
  array1: 1,2,3,4,5
  array2: 6,7,8,9
  final_array:1,2,3,4,5,6,7,8,9
I used build array function but the final array is a 2D array and i don´t want this.
Thank you
(2,811 Views)
Right-click the "Build array" function and select Concatenate Inputs
(2,807 Views)
Also you could use 'Insert into array' function
connect one array to 'array' terminal and other array to 'new element/ subarray' terminal of this function
Message Edited by devchander on 02-23-2007 04:28 AM
(2,791 Views)
