Linking .udl file to .mdb or .accdb in programming
I`m working on the database toolkits. I can manually create an .udl file andlink to .mdb or .accdb file. Can this be done through programmatically from LabVIEW?
Message 1 of 19
(5,492 Views)
Why dont you use two different udl file.one for mdb and one for .accdb and connect to them accordingly as per your requirement?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 19
(5,492 Views)
Hi Ranjeet,
I`m not using two different extension files i`m using either .mdl or .accdb file for an single .udl file.
Let me be more clear here I`m linking an test.udl file with the test.accdb. I can manually link the file by selecting the OLED function and specifying the path but I need to do this in program so every time when I run the program I can retrive those data if I have entered already.
Message 3 of 19
(5,481 Views)
@gnshmrthy wrote:
Hi Ranjeet,
The UDL is a text file, which you'll see if you open it in Notepad.
However, as suggested, it's alot easier to use 2 UDLs and choose/select between them.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 19
(5,480 Views)
I gave up using UDL files a long time ago.  I find it so much easier to use connection strings.  You'd be able to build the connection string any way you need.
Jim
Message 5 of 19
(5,460 Views)
UDL is essentially a connection string. It has the connection information and all the same info in a connection string. If you open a udl file, you will see all the connection info as in the connection string.
Message 6 of 19
(5,451 Views)
To be very clear mdb comes into picture when you are working on office 2003 and other when office 2007. Then what I suggess is to use mdb file all the time as it will be compatible with office 07 also but not accdb file and it will solve your problem of switching.
Hope this help.
--Ranjeet
Message 7 of 19
(5,428 Views)
Yes, since it's a normal textfile, is the short answer, the longer answer is to look at the tips and comments above. 🙂
/Y
Qestit Systems
Message 8 of 19
(5,418 Views)
The fundamental point that you seem to be missing is that you don't need the udl. What you need is the connection string that is inside the udl. So if you are going to generate the string on the fly, why waste the effort to write it to a file. As has already been suggested, use the connection string directly.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 19
(5,407 Views)
yes mike is also right. For accesing the mdb file you dont need udl file. See this
--Ranjeet
Message 10 of 19
(5,399 Views)
