Linking .vi's
Sorry if this is an stupid question, but I was wondering if someone could tell me how to do the following: I'll be running two .vi's simultaneously during some work I'm doing and rather than having both front panels up at once I'd like to link them so that when a particular property being monitered by one .vi goes outside of a given range of values, it causes a LED to illuminate on the front panel of the other, alerting me to the problem. Is this possible? If so, what is the best way to go about it?
(3,181 Views)
Have you tried making the LED you want to illuminate a Global variable?
(3,181 Views)
Spot on - thanks!
(3,181 Views)
