Linux - Cannot find file containing LabVIEW Configuration Settings
Hi everyone,
I am using LabVIEW 2019 (64Bit) in a Linux environment (CentOS 7) and I am trying to find the file that contains the configuration settings stored by LabVIEW.
In Windows, the settings are stored in “LabVIEW.ini” which typically can be found in "C:\Program Files (x86)\National Instruments\LabVIEW 20xx". In Linux, the settings should be stored in a “.labviewrc” file in both the program directory (i.e. system-wide settings) and the home directory (i.e. user-specific settings).
Unfortunately, I was not able to find any “.ini” or “.labviewrc” file in any directory (I searched in all directories, not only the program and home directory).
Additional information:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PA7rSAG&l=nl-NL
(4,826 Views)
I couldn't find a file named .labviewrc but on CentOS 7 there is a file in /home/vitech/natinst/.config/LabVIEW-xxxx called labview.conf which looks the same as the regular labview.ini file
(4,777 Views)
Hi everyone,
FYI: There is indeed a file path "/natinst/.config/LabVIEW-20xx" in the "home" directory which includes a file called "labview.conf". This file seems to include the LabVIEW configuration settings that I was looking for. I was not able to find it in the first place since both the file path and the file itself are hidden.
(4,741 Views)
