Linux Labview using cDaq (9171 and 9185) getting started
we are using Labview since years but almost only on Windows because of the driver problems.
But now they have a supports and we bought the cases 9171 and 9185.
Linux does not have MAX so i use the "Hardware Configuration Utility" and I find the cDAQ-9171 as a USB device and the module which i Installed.
The case and the module are telling me in the Self-test that "The driver communication successfully with the device".
Now i have the problem, that I don't know the "resource Name".
And for the 9185 I don't know where to start.
Is there maybe a tutorial to get cDaq's working under Linux?
opensuse 15.3
Labview 2022Q4 & 2023Q1
from lsni -v: (9171-Usb and 9185-Network are plugged in)
System Configuration API Experts found:
NI-DAQmx 23.0 (daqmx)
NI Device Interconnect Manager 23.0.0 (nidim)
NI-CONTROLLER 23.0 (ni-controller)
NI Network Browser 23.0 (network)
NI MX Routing Utility 23.0.0 (nimru)
NI-MXI 23.0 (ni-mxi)
NI PXI Platform Services 23.0 (ni-pxi)
NI-QPXI 23.0 (ni-qpxi)
NI-RIO 23.0.0 (ni-rio)
NI 5110 Digitizer 23.0 (niscope5110)
NI 5164 Digitizer 23.0 (niscope5164)
NI 5170 Digitizer 23.0 (niscope5170)
NI System Configuration 23.0 (nisyscfg)
NI-RTSI 23.0 (rtsi)
System Configuration API resources found:
cDAQ1
--Primary Expert:       NI-DAQmx 23.0
--Model Name:           NI cDAQ-9171
--Serial Number:        021EAAEA
cDAQ1Mod1
--Model Name:           NI 9220
--Serial Number:        01C7DC4C
localhost.localdomain
--Primary Expert:       NI System Configuration 23.0
--Model Name:           LIFEBOOK E459
Ethernet Adapter eth0
Ethernet Adapter eth3
Message 1 of 1
(15,755 Views)
