Linux Port IO and Network Communications?
I am considering using LabVIEW for Linux for an embedded single board
computer application but have little experience with Linux.
I have written a LabVIEW driver for the analog and digital I/O ports on the
single board computer using the I/O port VIs in Windows 98. I seem to
remember discussion about a third party port I/O driver available for
LabVIEW for Linux. Is this true and where can I get it?
What is available for network communications in LabVIEW for Linux? Can you
use DataSocket? I would like to have a centralized computer, possibly
running Windows, monitoring several of these embedded computers running
Linux.
Best Regards,
Neal Pederson, President, VI Control Systems
1923 Mendius Lane, Los Alamos
, NM 87544
TEL: (505) 662-1461, FAX: (603) 388-4969
np@vicontrols.com, www.vicontrols.com
(3,368 Views)
> Linux.
> Best Regards,
os, NM 87544
Neal,
There are TCP/UDP vi's working on LV/Linux as well as Internet toolkit.
DataSocket client vi's are on LV6/Linux only (server is still
unavailable as far as I know).
There is also Xserver capabilities to send data securely to remote
client, so you can use even front panels from remote device application
on the host machine.
Port I/O may be used if you have appropriate port driver (e.g.
/dev/name.o). In another case you'll have to make some C coding for the
device driver.
I saw the mention and site like "open source CIN project", but don't
remember it's URL. There was Inport/outport vi available, made with CIN.
If I'll find it, will let you know.
Hope this helps,
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
(3,368 Views)
>> on the
>> Can you
>> Linux.
>> Best Regards,
>> Neal Pederso
>> 1923 Mendius Lane, Los Alamos, NM 87544
> Neal,
> device driver.
> Hope this helps,
Here is URL:
http://sourceforge.net/projects/cin4labview/
Sergey Krasnishov
______
Moscow, Russia
(3,368 Views)
I have rewrite the Inw.vi and Outw.vi in order to work on Linux. Here are my files (Inw.vi, Inw.c, Outw.vi, Outw.c)
the .c files where compiled with the command :
gcc -fPIC -shared -o
Pascal Greliche
pascal.greliche@libertysurf.fr
(3,368 Views)
