Hi all, I've the same problem with LV7.1/DaqMX1.5.
I need to read voltages from a PCI-6023E/6024E card.
With the box "
Disconnect type definitions and remove unused polymorphic VI instances" checked, app builder hangs and I must kill LV.
With the same control unchecked the build hangs for a while (one minute or so), then returns an error:
Error 1003 at .../LabVIEW Data/app/internal llb/67xx--Board Config.vi
Possible reasons
LabVIEW: the VI is not executable.
- Application runs fine in LV environment
- The same app is compiled with no problems on Windows
- Other apps that don't use DaqMX are compiled on Linux.
Any Idea?
Thanks for support.
Regards.
GV
