07-18-2008 08:33 AM
07-21-2008 07:45 AM
07-21-2008 12:21 PM
07-21-2008
07:15 PM
- last edited on
09-28-2026
05:47 PM
by
Content Cleaner
Hello rhauff,
I understand you are having trouble communicating through serial in Linux. Which Linux distribution are you using and what version of NI-VISA do you have installed?
What exactly is happening when you run your program? You mentioned that it works for 5 seconds but then stops. What is happening when it stops? Are there any errors being thrown?
Also, I think it would be most beneficial to try using a basic serial example in LabVIEW (Help » Find Examples) to see if you can get it to work. Navigate to Hardware Input and Output » Serial » "Basic Serial Write and Read.vi". It would also be helpful to perform an NI-SPY capture when running the program to help troubleshoot what is happening. For information on using NI SPY for Linux, please look here [link removed; article no longer available]. There is also another resource for troubleshooting serial communcation in Linux which can be found here. Hope this helps,
07-22-2008 07:07 AM
07-22-2008 09:17 AM
