Linux shared lib (external code) : used to work under LV 8.6 - fails under LV 2009/2010
Well... after spending hours searching for information about my problem, I finally decided to post my "message in a bottle"...
I have a linux shared library that used to work like a charm under LabVIEW 8.6 but refuses to run properly under 2009/2010. LabVIEW gurus (authors?), here are my questions :
1 - What is the official gcc version for LabVIEW 2010? I mean, which gcc version is binary compatible with LabVIEW 2010? Which gcc version did you use to compile LabVIEW for Linux?
2 - Do you confirm that the NumericArrayResize signature changed ? I talking about the semantic of the last function parameter : totalNewSize. Under LV 8.6 it used to be documented as : "New number of elements to which the handle should refer". Today, its documentation is : "New number of elements, in bytes, to which the handle should refer". My code worked perfectly, but I now systematically obtain error code "1" when trying to resize an array using NumericArrayResize.
I'm lost ! Your help is warmly welcome. Thanks !
N.L.
(3,008 Views)
Some additional info...
Compiling the project using gcc-4.2.4 fixes the shared library loading problem I had (File Not found... Might have been moved... blablabla...). However, ResizeNumericArray still fails with error... 5! Error "5" is documented as "file already open"!
(2,997 Views)
Removing "liblv.so" from the linker options list (i.e. no more -llv) fixes the problem!
Could someone explain me why?
I'm really upset. Lost hours for nothing!
(2,994 Views)
BTW, the LV 2009 & 2010 documentation of NumericArrayResize is wrong! The totalNewSize parameter is still expressed in number of elements, not in bytes.
(2,987 Views)
