Linx Firmware wizard
when i interface the labVIEW and Arduino using linx ,arduino and labview is interfaced.But when i stop the labview code and again run the same code, data from arduino is not communicated with the labVIEW.If i again reload the linx firmware wizard to arduino ,communication is retained .How to overcome this!
(3,047 Views)
please post the code if you'd like help debugging it,
Cheers,
Tim
(3,035 Views)
