List Directory error
I'm using the File Dialog function with the following inputs:
prompt,
start path,
existing directory,
pattern as *.txt;*.lgg (my custom file name is *.lgg)
I feed the "path" output to the List Directory function and display
the "file names" output in a list box.
When I run this VI, a file dialog window pops up showing only
the *.txt files and *.lgg files as I want it to.
I press the button "Select current directory", the dialog box
disappears and a list of file names comes up in the list box.
The list box now shows all the files in the directory, among them
also some *.jpg files.
So I also feed the pattern *.txt;*.lgg to the List Directory function, but
then no files are displayed in the list box.
How do get only the preferred files
output from the List Directory function?
arild
Message 1 of 1
(3,654 Views)
