List Folder Function not returning all file names
Hello
I am having an issue with the List Folder Function. It is only returning the 1, 10th, 100th, 1000th and then 1001,1002.... image files within a folder. Does anyone know why i am having this issue? I have used this function before and have not run into this problem. I have attached a picture of the array of file names that is being returned and my VI.
(4,513 Views)
Are you sure they're not all actually there?  Files are listed alphabetically not numerically.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(4,506 Views)
It looks like you are correct that all the image files are there. They are just not in numerical order. Is there an easy way to put the files in numerical order?
Ryan
(4,407 Views)
Ryan
(4,406 Views)
Accepted by topic author chivasmaniac12
search for a numeric sort of string array on the forum and you'll get plenty of hits (you might want to also consider sorting 2d array of string)
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(4,403 Views)
I ended up just sorting the array with a "logical sort array" vi I found on the forum.
Ryan
(4,398 Views)
To make it easier to search and organize - especially for humans - use leading zeroes when naming the files.
Bill
CLD
(Mid-Level minion.)
(4,379 Views)
