List Folder VI pattern input
I would like to search the *.c,*.h and *.cfg files using List Folder and finally to find out / filter the folder path alone for the selected *.c,*.h and *.cfg files.
How to do that?.
Is it possible to give *.c,*.h,*.cfg as a pattern input to the List Folder? If i give *.c,*.h,*.cfg as a pattern input it is goving error.
please help.
Message 1 of 11
(11,017 Views)
The "pattern" uses the same sintax as the wildcards of the dir (Windows) command, so you cannot use  "*.c,*.h,*.cfg".
Use instead List folder three times, one for each extension, and then join the files you get
Marco
Message 2 of 11
(11,005 Views)
In windows it is possible to search using the combination of *.c,*.cfg,*.h.
If it is same as windows it supposed to work. please correct if i am wrong?.
Please send example document which gives details related to pattern or regular expression.
Message 3 of 11
(11,003 Views)
seperating the file name with semicolon works for file dialog but not for list folders
You can try something like this
Message 4 of 11
(11,001 Views)
Is it possible to remove the duplicate file name from the filename output from the List folder?.
whether i need to use complicated sorting?
Message 5 of 11
(10,992 Views)
This only returns the file extension you will specify. Also you can check this recursive vi
Message 6 of 11
(10,973 Views)
Hi!
Kals, do you expect to have files with the same name in the same directory?
Message 7 of 11
(10,969 Views)
The file name would be same in different directory. But the output from list Folder filename is going to same. i would like to remove duplicate filename.
Message 8 of 11
(10,954 Views)
You can delete it from the array that you are getting right?
Message 9 of 11
(10,946 Views)
I edited the idea slightly.
This vi accepts a pattern string separated by semicolons and outputs a 1D array instead of a 2D array.
This is how the "List Folder.vi" SHOULD work.
Message 10 of 11
(10,446 Views)
