List all the dependants VI for under main VI
Hi .
I have to list down all the dependent(calling) VI from main VI. As we know , the vi hierarchy gives the graphical representation. Is there any way we can list down all the VIs name and its location some where in excel or note pad etc?
Anand
Message 1 of 8
(5,242 Views)
Hi Anand,
open the MainVI.
Now you can use a property node to get a list of all VIs in memory: this will be your MainVI with all its "dependent" subVIs…
Message 2 of 8
(5,227 Views)
Create Project File, In the Project Explorer Right Click Main VI and Select Sub VI's it will list the SubVI's along with associated controls used.
same can be exported.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 3 of 8
(5,227 Views)
Hi Gerd,
I am hoping that "Application-All Vi in Memory will list all the VI's which are opened in LabVIEW Environment will be displayed. It wont give us only the SUB VI's associated with the Main VI."
Message 4 of 8
(5,225 Views)
Hi Palanivel,
Yes.
Anand asked for "all dependent VIs", so I gave the suggestion to just open the MainVI and then list "all VIs in memory"…
Message 5 of 8
(5,221 Views)
Message 6 of 8
(5,190 Views)
Thanks you.
Anand
Message 7 of 8
(5,179 Views)
@paul_cardinale wrote:
Good one!
Message 8 of 8
(5,173 Views)
